Engineering Design Data: Menu - heat transfer
heat_transfer
  • HeatConductionPipeInsulation
  • heatlossinsulatedpipe
  • Prev Page | Next Page
    Pages: << 4 5 6 [7] 8 9 10 >>
    Maximum Power Dissipation Transistor Equations and Calculator
    Maximum Power Dissipation of a Transistor Equation and Calculator: Assumptions: 1 Steady operating conditions exist. 2 The transistor case is isothermal at 85°C.
    Heat Loss Insulated Electric Wire Equations and Calculator
    Heat Loss From an Insulated Electric Wire Equation and Calculator:
    Natural Convection Radiation Thermal Resistance Table of Heat Sinks
    Combined natural convection and radiation thermal resistance of various heat sinks used in the cooling of electronic devices between the heat sink and the surroundings. All fins are made of aluminum 6063T-5, are black anodized.
    Heat Loss Insulated Pipe Equation and Calculator
    Heat Loss through a Insulated Pipe Equation and Calculator
    Heat Loss Double-Pane Window Equation and Calculator
    Heat Loss through a Double-Pane Window Equation and Calculator
    Single-Pane Window Heat Loss Equation and Calculator
    Heat Loss through a Single-Pane Window Equation and Calculator
    Heat Loss Through Wall Equation and Calculator
    Heat Loss Through a Wall Equation, Calculator and a design example
    Insulating Materials Thermal Properties
    Thermal Properties of insulating materials (at a mean temperature of 24°C)
    Convection Heat Transfer Coefficients Equations and Calculator
    Simplified relations for natural convection heat transfer coefficients for various geometries in air at atmospheric pressure for laminar flow conditions.
    Estimating Transistor Heat Transfer Equation and Calculator
    Estimating Junction Heat Transfer and Temperature of a Transistor Equation and Calculator
    Disclaimer
